Part Number: 358851 Grind Number: R-284/420-2S1-12
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1968 Up FORD-MERCURY 8 COMPETITION ONLY, GOOD UPPER RPM HP, 510+ CU. IN., BRACKET RACING, NITROUS, AUTO TRANS W/RACE CONVERTER, 13.0 MIN.COMP. RATIO ADV. BASIC RPM 5000-8200
Engine Size Configuration
370-460 C.I. V
My friend just purchased a T/K car from one of my other friends. He decided to pop the cam cap off while the trans was out for inspection. 598 BBF C Head motor with this cam still made 1012 hp on a superflow dyno. This cam has 12 runs on it & comes with everything springs etc.... Located in nor cal.
Thanks for looking ! 415 328 3266 cell
$400. for Everything ! Thanks for looking
Valve Setting: Intake .020 Exhaust .020 HOT
Lift: Intake @Cam 420 @Valve 718 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 420 @Valve 718
Rocker Arm Ratio 1.71
Cam Timing: TAPPET @.0205
Lift: Opens Closes ADV Duration
Intake 49.0 BTDC 87.0 ABDC 316.0 °
Exhaust 96.0 BBDC 46.0 ATDC 322.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99885
Loads Closed 215 LBS @ 1.950 or 1 61/64
Open 622 LBS @ 1.280
Recommended RPM range with matching components
Minimum RPM 4800
Maximum RPM 8400
Valve Float 9000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 34.0 BTDC 70.0 ABDC 107 284.0 °
Exhaust 81.0 BBDC 29.0 ATDC 117 290.0 °
