I have a crane solid roller cam for sale. Not a whole lot of run time on it. I am going in a different direction and am not needing this rpm range. $125 shipped.Thanks.
Part Number: 358081 Grind Number: TR-264/4167-2-8
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1968 Up FORD-MERCURY 8
Engine Size Configuration
370-460 C.I. V
Valve Setting: Intake .022 Exhaust .022 HOT
Lift: Intake @Cam 4167 @Valve 713 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 4167 @Valve 713
Rocker Arm Ratio 1.71
Cam Timing: TAPPET @.0195
Lift: Opens Closes ADV Duration
Intake 43 BTDC 79 ABDC 302 °
Exhaust 84 BBDC 48 ATDC 312 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99885
Loads Closed 215 LBS @ 1.950 or 1 61/64
Open 622 LBS @ 1.280
Recommended RPM range with matching components
Minimum RPM 4000
Maximum RPM 7400
Valve Float 8000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 27 BTDC 57 ABDC 105 264 °
Exhaust 68 BBDC 26 ATDC 111 274 °
Remarks:
USE .018" LASH FOR CONTINUOUS HIGH ENGINE SPEEDS.
