I have a Crower Cam that I would like your opinion on this combination.
466
11.3:1 Compression
Victor intake
1150 Dominator
Iron 429 CJ Heads(Ported Exhaust)
Camshaft
Solid Lifter
Intake 250 at 0.050, .571" Lift
Exhaust 256 at 0.050, .590" Lift
108 lobe separation
Installed at 104
Any suggestions?
Yes, it is going into a street car!
Thanks!
Author Reply
Bret
(no login)
208.31.189.240 Too much carb?
No score for this post December 30 2001, 11:56 PM
If this is for street, I think an 850 would be adequate and much more streetable. However, I don't pretend to know it all. GOOD LUCK!
Canuck
(no login)
24.71.223.142 Thanks for your reply
No score for this post December 31 2001, 12:29 AM
Hi!
I know that the 1150 seems like too much carb but I have modifed it to only run on the first two barrel until full throttle.
I do believe its the progressive carb cam I used it the set up.
Terry
Just Strokin
(no login)
208.62.208.135 Too much carb
No score for this post December 31 2001, 7:30 AM
What you might try to locate is the Holley Dom model 80186 (I think is the number). It is a 750 cfm in the 4500 model line.
Ken
(no login)
216.209.119.112 Excellent
No score for this post December 31 2001, 9:48 AM
Sounds like a good setup. I have run the same basic setup. The carb is fine, especially if you like topend. However for all around driveability, a 950 might be better. An 850 is done by 6000 rpm. if your heads are good. You need a least a 2 1/8" header.That particular grind will run hard from 5800-6600
canuck
(no login)
24.71.223.142 Re: Excellent
No score for this post December 31 2001, 1:03 PM
Thanks for all your input to everyone!
Terry
466
11.3:1 Compression
Victor intake
1150 Dominator
Camshaft
Solid Lifter
108 lobe separation
Installed at 104
Any suggestions?
Thanks!
Author Reply
Bret
(no login)
Canuck
(no login)
Hi!
Terry
Just Strokin
(no login)
Ken
(no login)
canuck
(no login)
Terry
