Status
Not open for further replies.
CarsByCarl is proud to offer the following BLOWOUT specials on MONDAY 11-26-2012 ONLY.
_________________________________________________________
Tall Fabricated Aluminum Valve Cover Big Block Ford
Suggested retail $159.95. Cyber Monday BLOWOUT price $99.95
-Short bolt design with notched ends to help with accessory clearance.
-Thick gasket mounting rail to maximize sealing.
-long bolt design to maximize clearance for stud girdles, etc.
--Thick gasket mounting rail to maximize sealing.
429/460 HEI Distributors
Suggested retail $99.95. Cyber Monday BLOWOUT price $59.95
High quality brass terminals and a protective plastic dust cover that encapsulates the 65,000-volt coil. A new cast-aluminum housing featuring a machine polished finish contains new bushings, mainshaft assembly, and a hardened steel gear. Our HEI includes high-output module, centrifugal advance components, and adjustable vacuum advance canister.
Phenix Industries
Suggested retail $149.95. Cyber Monday BLOWOUT price $59.95
-Holley 4150 Dual Feed Inlet Kit (#H5115-2)
-Made in the USA!
______________________________________________________________
Heartthrob mufflers
Suggested retail $94.95/ea. Cyber Monday BLOWOUT price $49.95/ea
-Made in the USA!
Heartthrob Velocity series mufflers:
5" x 11" x 14" case
3" center in - center out (for maximum flow)
More flow and less back pressure than most other chambered designs, including flowmaster.
Heartthrob Velocity Series Mufflers (HVS) are a great choice for your vehicle. Heart throb exhaust has spent years developing and fine tuning the Velocity Series muffler. This Hearthrob velocity muffler flows amongst the best of welded performance mufflers on the market, is normally quieter inside the vehicle, and is still aggressive at the tail pipe. Call it having your cake and eating it too. Our unique center wing baffle isolates sound in the HVS muffler, and combined with our welded double-wrapped shell, sends the sounds to the tail pipe. You get excellent exhaust flow, a durable welded double-wrapped shell, lower interior sounds, and a powerful sound at the tail pipes. The 5-1/2” x 11” bodies flow better than the 4” x 9”, and the 5-1/2” x 11” bodies are quieter. These velocity mufflers are directional mufflers which are not reversible.
Heartthrob mufflers Build your own shortie header kit
Suggested retail $189.95/ea. Cyber Monday BLOWOUT price $129.95/ea
-Made in the USA!
Shortie kit:
-header flanges included
-1-3/4" primary tubes
-3" collectors
Status
