All,
I have a 521 that was built a couple years ago and I currently have it torn apart to discover what the engine builder had actually done vs. what I asked for. Im currently looking for cam timing recommendations for this combo. It will be going in a 1970 Torino with a C-6 and 3.91 gears...
Ok engine is on TDC. compression. Tmming marks line up dot to dot
I removed the old Dizzy taking note of the rotor direction and its relationship with the #1 on the cap .
Installed new Dizzy and pointed rotor in same direction as old but when i put the new cap on the new Dizzy # 1 was...
Have an EGR valve on my stock intake 85 or so vintage E250 Van engine 460ci. Want to remove the EGR and block off the exhaust opening on the intake and add a 1 inch spacer and then a Edelbrock carburetor. I know I can just leave the EGR in place disconnected as a spacer. But I'd like to not...
Dont know what thread this should be under but I'm having the hardest time ever finding valve covers. I have a 91 460 efi with E7TE-BD heads. They have the center bolt pattern and I cant find anything. And all google wants to give me is small block chevy. Anyone know where I can get ones? Dont...
Guys,
I have an in the works 521 and I'm trying to figure out what intake manifold I should use. Engines going in a 70 torino with a c-6 and 3.91 gears. Street /strip car
Build as follows:
521 10.7 compression ratio
D00E-R heads mild cleanup on exhaust
Solid lifter comp cams 34-652-5...
