done a mock up on my motor last night installed #1,4,5,& 8 pistons installed head with no gasket was checking valve clearance and deck height, with piston at tdc the intake valve has .355 clearance and exhaust has .415 on all four corners, then took a stright edge with pistion at tdc run a feeler gauge under the stright edge .032 on right side and .030 on left side is this the best way to check this stuff or is there a better way. thanks for any input
