41 - 44 of 44 Posts
Following advice
Hi I have been following your advice for my 460. I put in an HEI distributor and was wondering if you knew how to work the vacuum lines. I had a dual vacuum points distributor before one line went to the carbs secondary vacuum. For now I have capped off the secondary vac at the carburetor. Should I link those vacuum lines with a T or just leave it as is?
Thanks Jima, The motor has 96k miles. one owner and well taken care of. There is a lot of chatter about timing chains. Do I need/should to do that too?
41 - 44 of 44 Posts
