Status
Not open for further replies.
Diamond Racing Piston Clearance Sale
This is a one time clearance price, never to be repeated, limited to stock on-hand.
These pistons would normally be priced at $850.00, but we're blowing them out for ONLY $549.95 per set :eek: pistons, pins, and locks included
Diamond Racing Pistons part #40504
  • 4.440 bore (+.080 overbore)
  • For use with stock dimension rods and crank, 3.850 stroke and 6.605 length rods with 1.040 pin
  • New old stock, only removed from packaging for photos
  • Forged 2618 alloy
  • H-13 tool steel pins included at no additional cost - normally a $100.00 upgrade - they are the strongest pins you can buy
  • For use with Kaase style SCJ / P51 and AFR heads ONLY.
  • While specifically made for SCJ/P51 heads, the valve relief will provide approx .150 valve pocket depth for AFR heads - please ask questions about this if unclear
  • WILL NOT work with D0VE D0OR-E C8VE C9VE D3VE Edelbrock ProComp Speedmaster Trickflow, A460 heads
  • Great for a pump gas build with AFR 85cc heads
  • Great for racing and/or E85 use with SCJ/P51, or AFR small chamber heads.
  • Approx 12.0:1 compression with 72cc heads
  • Approx 10.6:1 compression with 85cc heads
Diamond Racing Pistons part #40001
  • 4.390 bore (+.030 overbore)
  • Forged 2618 alloy
  • For use with stock valve location heads only. D0VE D0OR-E C8VE C9VE D3VE Edelbrock ProComp Speedmaster Trickflow, etc.
  • WILL NOT work with SCJ P51 AFR A460 heads
  • Great for a pump gas build with D3VE, Edelbrock 95cc, or ProComp/Speedmaster heads
  • Great for racing use with small chamber D0VE, Edelbrock 75cc, Trickflow, and factory CJ heads
  • Approx 11.4:1 compression with 75cc heads
  • Approx 9.5:1 compression with 95cc heads
Please call, PM, email with questions, or to order.
Status
