21 - 26 of 26 Posts
Discussion Starter · #21 ·
I got the old gears off and fitted the new ones on. The engine is at TDC and both crank and cam gear dots line up at noon and 6. However, my distributor is not facing #1. The black line on my distributor is #1. Why would that be off?
Gear Automotive tire Bicycle part Rim Automotive wheel system
Automotive tire Hood Motor vehicle Automotive design Bumper
Discussion Starter · #22 ·
Scratch that. As usual I was over thinking it. All I had to do was loosen the dizzy and turn it to match #1.
Another question though. The factory cam gear protruded out to allow the outer piece of the 2 piece fuel eccentric to spin freely when torqued down. The new Cloyes set is flat, so when the cam bolt is torqued down it seizes the outer piece of the eccentric against the gear. Should/could I put a thin washer between the eccentric and gear to allow it to spin freely again?
Automotive tire Fluid Rim Automotive wheel system Gas
Discussion Starter · #24 ·
HI
over thinking,,,, the new set is most likely a double roller and is thicker than the factory plastic gear just bolt it up .. the eccentric should not spin freely
good luck take care be safe
tim
It is a double roller. The factory 2 piece eccentric outer part is designed to spin freely. The 1 pieces are stationary.
You would do better to find a one piece eccentric.
The amount the dizzy rotor was advanced after the install is the amount the cam was retarded relative to straight up.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
77 Lincoln, did my worn out timing chain jump a tooth? I’m at TDC, and the only thing that seems to line up is the keyway at 12 o’clock. I’m aware this has the factory retarded cam timing for emissions but it still seems off. The cam gear marking is pointed towards the drivers side and not at 6 o’clock. Either way I’m replacing it to get rid of the plastic tooth gear and the chain is extremely loose.
It’s not jumped, and you are correct that is the retarded lower sprocket.
No, you have not jumped timing. And you were correct that is the retarded lower sprocket. Back in the mid/late 70s I was working in a Ford dealer where we got complaints of high dollar Torino Elite’s(or any 460 vehicle) that were doggy, got horrible gas mileage. We would put a 429 lower sprocket on and the tuneup guy would trick out the distributor, making a huge difference. You will probably need more than just a lower sprocket…
21 - 26 of 26 Posts
