· Premium Member
Hey Guys, Hep me out....
As some of ya know, I've been slowly working on building up a DIVE ('76) 460 to 501" with Edel's Al heads for dragracing use. In my quest to get the 'correct' oil pump, I've read of three sources that suggest using a Melling 429 CJ oil pump, with one source providing the part# of "M84 B HVS". When I spoke with my friendly parts guy, he said that isn't a correct number, rather I should order a "M84 E HVS" pump instead. Do you guys know which is which or if there is even any difference?
Thanks for your help in advance,
StickBBF
Author Reply
StickBBF
(no login)
205.158.104.42 FRPP Pump...?
No score for this post October 12 2001, 12:00 PM
...maybe I'd be better served with a SVO oil pump?
Does anyone know if the SVO oil pump #M-6600-A460 is the same unit as the #M-6600-B4..?
-- Maybe just an updated part number?
Thanks for your hep, guys!
StickBBF
StickBBF
(no login)
205.158.104.42 Manufacturer's Resonse... :)
No score for this post October 12 2001, 1:27 PM
Hey Gang:
Earlier after I posted my request here, I thought of simply sending the question directly to Melling...
WELL, Kudo's to Tim Cross @ Mellings! - I've already gotten a response! For everyone's info, I've copied his response below...
Sir,
M-84BHV-S - (Exc-Police) use oil pan depth of 81/4", may require minor modification of oil pan, 60 psi @ hot idle, 75 psi @ hot by-pass, GPM: 3.75.
M-84EHV-S - (Inc-Police) use oil pan depth of 8 5/8", may require minor modification of oil pan, 60 psi @ hot idle, 75 psi @ hot by-pass, GPM: 3.75.
Regards,
Tim Cross
Melling Engine Parts
Bob M
(no login)
64.24.153.132 Bolt on pickup tube...
No score for this post October 12 2001, 9:45 PM
Make sure that whatever pump you use has a bolt-on pickup tube. That is probably why someone suggested the CJ pump.
Bob
StickBBF
(no login)
205.158.104.42 It does...
No score for this post October 18 2001, 4:55 PM
Bob M,
I ordered and now have the Melling #M-84-BHV-S oil pump; it has the bolt-on style pickup. Thanks for the tip!
