If the timing cover and timing chain are removed from your engine and you are able to grab the distributor shaft to pull it downwards while checking your measurement, then yes, the 0.011" clearance is excessive. At most it should be about half that.Ok one last check. I got the dizzy in the motor and I can get an .011 feeler gauge between the gear and the thrust surface.
Is that too much?
Did you do the check with the distributor clamped down in place? If not check it again.Ok thanks a bunch good info. So I tweaked on it a little more and while pulling it down a .004 feeler gauge mived smoothly within and a .005 had a little drag on it. So I should be good there right?
The thrust surface on the gear should ride on or just above the thrust surface on the block.Crap maybe its a little tighter than that still .003 moves smoothly. This is some tedious stuff.
I might have missed what the average depth of the thrust surface from distributer mounting surface? For an assembled and installed engine, is it acceptable to simply lower the gear to make up for worn thrust surface?There is no reason to have this be so complicated.
If when the distributor is dropped in and locked down the gear is touching the thrust surface AND you can move the shaft up 20 to 30 thousandths until the collar above the gear contacts the housing... RUN IT !!!
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
That was silly question, as lowering gear to make up for worn thrust surface will mess up cam alignment. What is acceptable practice for correcting worn thrust surface in otherwise healthy engine?I might have missed what the average depth of the thrust surface from distributer mounting surface? For an assembled and installed engine, is it acceptable to simply lower the gear to make up for worn thrust surface?
Long story short, last guy that worked on my engine before me and last builder installed a Motorcraft 12127CA with gear relocated incorrectly, I still have the dizzy and it measures about 4.122 dropped, about 4.038 up. Pulled cap and it was driving assembly through cap/dizzy. I ran this for about 3000 miles before pulling engine for rebuild because of vibration, etc, etc. Anyway, when I pulled dizzy at same time I pulled engine I noticed a metal shaving on the pad, mentioned it to machine shop/engine builder and was told it looked ok.If you're this concerned about tooth to cam on the distributor, paint some white grease on all of the distributor teeth. Drop it down and lock it in place. Spin the engine over 1 time.. in the direction it turns when it's running, it's not a rear end so no back lash to account for here. Pull the distributor and check the wear pattern.. if it looks good RUNNIT!! If it needs to go up get a shim from a Chevy distributor kit and shim it up a fuzz. You shouldn't have to fiddle about with it....
I should start out saying I’m just trying to learn how to set up my distributor to get more than a few hundred miles out of a new bronze gear. Thrust pad measures 4.034”, extended distributor shaft 4.031”, pushed shaft about 4.005+”. Used white grease on new gear and rotated a hair more than once, looks like contact high on one side of teeth and low on other.Long story short, last guy that worked on my engine before me and last builder installed a Motorcraft 12127CA with gear relocated incorrectly, I still have the dizzy and it measures about 4.122 dropped, about 4.038 up. Pulled cap and it was driving assembly through cap/dizzy. I ran this for about 3000 miles before pulling engine for rebuild because of vibration, etc, etc. Anyway, when I pulled dizzy at same time I pulled engine I noticed a metal shaving on the pad, mentioned it to machine shop/engine builder and was told it looked ok.
I installed a new Pertronix after rebuild and was having issues with an Igniter III after engine warmed up, ended up replacing with another new Igniter II with new bronze gear, only had engine break-in and 40 miles, still have the bronze gear with 40 miles on it sitting in my garage.
Got to reading this thread and decided to take a look at removed Motorcraft and bronze gear with 40 miles, good chance I have an issue.
I have Mag Trigger Pertronix on order because I need to retard timing at start for warm engine, can’t retard more than 4 degrees with an Ignitor II, so this weekend I’ll pull my Ignitor II dizzy with 458 miles and measure Thrust pad depth. Then try to figure out how much of a shim I need. I already know my gear is being pulled down too far by the wear pattern on the 40 mile bronze gear.
