As you know I run a 501" BBF in a flatbottom boat. This entails lots of continious high rpm running. Twice in two years the roll pin holding the cam gear to the distributor shaft has broken. The distributor is a dual point Mallory of 60's vintage. Except for the triggering mechanism, the new ones look the same.
I gather from discussions this may be a weak area of the Mallory distributor although other makes look similar.
1. Has anybody else experienced this problem?
2. Changing distributors is not a possibility as I
need the Mallory small cap for clearance purposes.
3. Two potential solutions are to replace the 1/8"
roll pin with a 5/32" pin. To ccomodate the existing hole in the shaft must be drilled larger. Any problems with weakening the shaft?
4. Replace the existing 1/8' pin with a spring wound pin which is supposed to be stronger?
Any advice would be welcome.
Author Reply
67f100
(no login)
209.162.57.54 Distributor gear pin breaking...
No score for this post July 14 2001, 4:19 PM
Usually this is caused by using a HV oil pump, and by also using heavier oil. Going to a larger pin would help the gear pin breakage, and use the hardest pin you can find. I don't know what oil weight you are using, but you might want to re-evaluate that. Too heavy a viscosity of oil can cause bearing failure, because of the lack of flowability.
gregaust
(no login)
203.17.162.31 mallory rollpin
No score for this post July 14 2001, 9:55 PM
I have had the same problem with a couple mallory twin point dist's over the years.One i repaired just a couple weeks ago i drilled the gear+shaft to 5/32.The previous one i drilled to 3/16 and fitted an original ford roll pin.I don't think drilling the shaft would make it any weaker as the original ford dist's have a 3/16 pin stock .I remember seeing an article a few years ago that adressed this prob + suggested the larger size pin.
HOPE THIS HELPS.
Bob MacD
(no login)
24.112.158.243 Thanks for the ideas
No score for this post July 14 2001, 11:27 PM
Yes I am using a HV pump and 15-50W synthetic oil. I will drill out the hole to 5/32" and use a coiled pin for strength.
Ken
(no login)
165.154.190.1 Easy fix
No score for this post December 13 2001, 2:04 PM
move up the shaft and 90 degrees to the existing pin, drill a second hole and put in a second pin. Go as high as yopu can for seperation. Haven't broken a pin in years.
Author Reply
67f100
(no login)
gregaust
(no login)
HOPE THIS HELPS.
Bob MacD
(no login)
Ken
(no login)
