...that you wouldn't have to mow lawns for 25 years to pay for?
Author Reply
mcs
(no login)
216.224.144.212 RJP, can you give me some help on this please?........n/m
No score for this post November 18 2001, 11:36 AM
RJP
(no login)
152.163.204.214 Not much help but,
No score for this post November 18 2001, 3:29 PM
All I can offer is the Raceparts Distribution [704-892-8688] piece as this is the only 429-460 aluminum block made that should hold water. Last I heard they were dry sleeve. Still going to be big bucks so better find some more lawns to mow. I had to get another paper route to pay for my stuff.
mcs
(no login)
216.224.155.162 Thanks pal.....n/m
No score for this post November 18 2001, 3:33 PM
Mark J.
(no login)
63.10.102.2 RDI Std Deck
No score for this post November 20 2001, 1:36 AM
Got mine from RDI $3500.00 Has capability to run 18 head fastners. This one of the reasons I love it.
Later,
Mark J.
mcs
(no login)
216.224.143.92 Do you have a little more info on this? Thanks...n/m
No score for this post November 21 2001, 10:26 AM
Mark J.
(no login)
63.29.25.118 More Info
No score for this post November 22 2001, 6:32 PM
RaceParts Distribution Incorporated a.k.a. RDI. Block is available with stock deck height of 10.32 ( the least expensive), 11.20, 11.70,& 12.00 or 5.0" bore spacing with 12.0 deck height. Comes with nodular iron or aluminum 4 bolt caps 3" mains. Any BBF head will fit. Siamese bores. Shipped set up for dry sump system but can be drilled for wet sump. Had mine shipped set up for roller cam bearings. Had to clearence for 4.5 crank. Had to work tops of lifter bore so lifter links would not strike top of lifter bore. Would be glad to answer any other questions you might have.
Later,
Mark J.
mcs
(no login)
216.224.144.229 Thanks much...sounds great!...what do...
No score for this post November 23 2001, 10:27 AM
you run it in?
Mark J.
(no login)
63.42.220.127 '65 Mustang......
No score for this post November 23 2001, 10:20 PM
Mild steel chassis (2640lb with me in it) Lenco, Enderle hat on alcohol. 5.0's 1/8th & 8.0's in the 1/4. Ordered moly to bend up new lighter chassis. Maybe I will loose a couple of hundred pounds after all is said & done and be able to hit the 7's hard.
Later,
Mark J.
Author Reply
mcs
(no login)
RJP
(no login)
mcs
(no login)
Mark J.
(no login)
Later,
Mark J.
mcs
(no login)
Mark J.
(no login)
Later,
Mark J.
mcs
(no login)
you run it in?
Mark J.
(no login)
Later,
Mark J.
