1 - 20 of 23 Posts
One set of CJ heads, fresh from machine shop
comes bare but includes the following:
lunati roller springs, part #74726 maybe has 6 runs on them
comp 3/8 guide plates
comp 10 degree retainers
comp 10 degree locks standard height and +.050 height
stud girdle with poly locks
also comes with original valves, retainers, & locks, rocker studs, and guide plates
also has valve seals
$1300.00
Lunati roller cam, part #516A5
Advertised Duration (Int/Exh): 313/324
Gross Valve Lift (Int/Exh): .738/.738
LSA: 110
RPM Range: 5000-8500
@50 duration 282/292
maybe has 6 runs on it
$150.00
Also have stock cj intake iron $150.00 It might be a scj it is the holley bolt pattern
MSD adjustable timing control can change timing up to 15 degress from a knob in the cab $75.00
They are hedman huslers with the 2" primaries i ut some more pics of the headers and the victor 4150 intake with the steel keenserts
1 - 20 of 23 Posts
