Can anyone tell me if it’s worth putting over size valves in dove c on 1997 stock block
So it’s not really worth Changing valves thenThe valve notch on the OEM EFI pistons will not allow a valve larger than 2.15". The notch diameter is too small for anything larger.
We use a 2.110 Ferrea valve in all of the passenger car and EFI iron heads. We've found that for up to about 550 HP this is adequate for the pocket port work and port cross section.
A larger valve with out a concurrent increase in cross section offers no more peak flow. Slightly better low lift flow if the chamber is unshrouded and other chamber mods are done.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
Do you have a picture of the notching toolI'm actually doing this same build. 97 Short block with D0VE heads except mine already has 2.25" intake valves so I'm using a notching tool on the pistons. This is what Ford did with the crate engines back in the day so I'm told. Everything I have read indicates that this will be a nice combination.
Well I’m on a Budget but if I could get in the 400s I think I would be happy. Since it’s a truck I guess I’m Mainly looking for torqueBefore you do anything. How much power are you attempting to make?
Simply tossing larger valves in the heads with out the requisite port work and bowl sizing can be counter productive.
Custom ground cams
R-H-P.biz
(253)-988-6648
Custom ground cams
R-H-P.biz
(253)-988-6648
Was told you were the one ask about a cam for my build what do you recommendWell I’m on a Budget but if I could get in the 400s I think I would be happy. Since it’s a truck I guess I’m Mainly looking for torque
