If you are mounting a dry sump pump with out a front engine plate are they mounted by using the upper bolt hole that the alternator is usually mounted to and the smaller lower hole next to the front cover? I see moroso sells a bracket, but if that is all there is to the bracket it would be easy enough to make.
Kyle
Kyle
