1 - 3 of 3 Posts
Couple of questions:
1 Can the reluctor be installed 180* out of phase without any neg effects?
2 Can the top end parts of the Duraspark be interchanged between the BB and SB?
3 Is there an easy way to lock the plate if the vacuum adv mechanism is removed?
The reason for all the questions is I got my Comet running again after a 5yr storage and have no more plans to race. I pulled my dual pt and installed a Duraspark to fire my Jacob's ign box. Since the old dist was set up to run at 8000+ and needed to start easily, it had 44* total and set at zero initial....(don't laugh, it worked really good...LOL). I have a few BB Duraspark's in various conditions but only 1 for a SB.
Before I assemble what I want with what I have, I need the answers.
Thanks guys.
Mark
Thanks guys.
Mark
yes, parts are the same, except for gear, and shaft on your small block, you can install the wheel wrong, it has a alignment pin
I either weld the plate,or drill a hole thru top and bottom then install a screw to hole it,you will need to install shims between top and bottom plate .(washers work fine)
If you interchange the wheels from a different dist, how will you know if it's out 180* ?
1 - 3 of 3 Posts
