1 - 6 of 6 Posts
Friday is dyno day what do you guys think I can expect I've got a 552 with port matched scj aluminum heads 10.4 compression victor port matched intake with a 1050 pro systems dominator 2-1/8 inch headers flat solid cam 260/266 with .636/.663 lift it'll be chassis dyno through a six speed standard trans whattaya yall think
dyno
well I'll put my 2 cents in, I think your combo would make north of 850 HP if you had more cam and compression but with the modest cam and compression it will make 650-700 HP and 650-700 tq, good luck with the dyno and let us know
[email protected] isnt small..... but for 552" @10.5 its ok.....
th 2.125 headre will shut it off on th top.....a 4" collector would help....
all in all w out flow # wer really guessen.... ....
we all kno scj are lackin on exh flo....
so that shuts it off on top.....
long story short shud b good torqer....
hp wise.....if u get over 1.25hp/cu" corrected hp.....better check dyno....lol
@650/700hp corrected at flywheel about it.....
one thing....wats application?????
r we racing dynos or building for street use....c my point....
256/266 @ 110 installed at 105 might du better thru th rpm range...
Any pocket work or back cut on the intake valve???
S
1 - 6 of 6 Posts
