1 - 18 of 18 Posts
Well done great to see mean an clean. Pity i ve got no fucken idea e85 is. Now tell me what magic you can do with LPG that gives you 110 octaine rating with minimal emissions
What parts have to be different in the engine to run E85?
Internally these engines have different cam profiles and compression than my gasoline engines. They will also require an alcohol compatible carb and fuel system.
what kind of compression can you run with e85? big compression or does it have to be small?
e85 will tolorate significantly more compression than pump gas.
Discussion Starter #12
Bump
Discussion Starter #13
TTT
Discussion Starter #14
:cool:
Discussion Starter #15
Earth day bump.
Sell the prius, drive an e85 BBF. :D
1 - 18 of 18 Posts
