1 - 8 of 8 Posts
Used Edelbrock Victor Intake Manifold Part Number 2966
The following modifications have been made to this manifold
1. A hole was added to the front water passage to allow a water temp sensor to be installed. This hole could easily by plugged if you do not want to use it.
2. A hole was added in the rear valley pan area to allow a vacuum gauge to monitor crank case vacuum. I already have a plug installed in this hole. It's in the back and is not easily noticeable. Does not affect anything if you do not use it.
3. The intake ports have been ported to match Fel-Pro Intake Gasket 1231. Those gaskets can be found here:
http://www.summitracing.com/parts/fel-1231/overview/make/ford
The manifold is in good condition, no stripped threads.
$200, plus shipping.
Intake still for sale. Yes I accept Paypal. Shipping will vary based on your location but so far a few test zip codes show shipping to be between 23 to 40 dollars. You could also pick it up if you live near Toledo Ohio.
1 - 8 of 8 Posts
