To start this off im 18 and I dont really like carbs and I have an efi 460 so I started searching for a way to run efi with any cam and motor combo I want. So over a year ago I did a MAF conversion using a fiveology racing kit on my 460 and all went well. Then I had to get the truck tuned because the 94-95 mustang ecm was having trouble learning the motor and all smog codes were deleted. So then I deleted the egr and smog pump to clean up the engine bay and I was happy with it but im saving toward a built motor and I saw how bad the stock intake elbow was so now my latest project is converting it into a single blade throttle body and aftermarket intake elbow. I just ordered the efi to carb bracket and am ordering my throttle body and intake elbow tomorrow. The elbow is a 90mm elbow for a foxbody and the throttle body is an 80mm for a foxbody. After doing all this I will be ready to put in a built motor when the time comes. Im going to keep updating this post as not many people have done and is hard to find info on.
91410
91411
As a reference this is the stock elbow.
91412
I was speaking about this with a caller a day or so ago.
As bad as that elbow looks it is not an impediment to a 400 hp EFI crate engine like we build. With a 61mm BBK throttle body it supported a 500 hp 545 EFI stroker.
The HD 429 EFI snake is open.
If you want to mount a 4150 elbow on the OEM intake there is an adapter I can have made to allow this.
You could also mount a 4 barrel TB on our HP4150 adapter.
Russell at 460 EFI guys also has some options.
SJ
used 2b RHP
SJ
used 2b RHP
Yep I remember the conversation I have an adapter plate on the way and ordered my parts today. I just want an easier to work on motor and something nice for people to look at when the hoods open.
Well I’ve followed through and put the parts on the truck I’m waiting for the intake tubing to come in Monday or Tuesday and I will be able to report back with more.
91450
Finishing up this thread the trucks running and I still have some minor throttle adjustments to do but everything turned out pretty decent. As for gains it was a half a second quicker down low and the stock whine at high rpms is gone. It is rather twitchy but the tuner said he would take care of that.
91480
