1 - 12 of 12 Posts
Hello all, first time posting here. Starting a build and have not found any heads besides stock refurbished ones for a ‘96 block, I’m assuming this is because of the efi. All heads I have seen are for engines before 1987. Has anyone found heads meant for post 1987 engines? Will these heads work for mine?
Thanks,
Dylan
There are no dedicated performance castings for the EFI architecture.
Having said that a properly sorted out EFI engine with a custom cam, Pocket ported heads and intake runner work WILL make 380 to 400 hp and 500 to 525 lb feet of torque all while operating quite well with the OEM EFI system and an adjustable FPR from aeromotive.
Headers and free flow exhaust as well as low restriction intake are needed.
Any more HP and the power band moves up out of that which is appropriate for a work engine.
SJ
used 2b RHP
:D
Having said that a properly sorted out EFI engine with a custom cam, Pocket ported heads and intake runner work WILL make 380 to 400 hp and 500 to 525 lb feet or torque all while operating quite well with the OEM EFI system and an adjustable FPR from aeromotive.
SJ
used 2b RHP
<img src="http://460ford.com/forum/images/smilies/biggrin.gif" border="0" alt="" title="Very Happy" class="inlineimg" />
Any suggestions for bore and stroke for this application?
Std stroke and minimum overbore.
What is your application and intended use?
Location and altitude?
SJ
used 2b RhP
:D
SJ
used 2b RhP
I
It is going in an f 350 mainly going to be used off road and on desert/camping trips. trying to get as much power as I can without compromising the integrity.
Southern California pretty close to sea level
What year is the truck?
Do you have to pass Cali emissions?
SJ
used 2b RHP
:D
SJ
used 2b RHP
It’s a 94
technically yes have to pass emissions
It’s a 94
Our 460 EFI engine package is Cali emissions compliant.
SJ
used 2b RHP
:D
1 - 12 of 12 Posts
