Hi guys, i am thinking of setting up multi port efi on my P-51 headed 557. I guess my first question is, does the Edelbrock Victor EFI manifold fit the P-51 heads, or more to the point, can it be port matched at all? I would rather use an off the shelf manifold, but if i have to i will modify my Offy manifold or modify a standard victor manifold.
hello, i know this is a couple months old but i just got my multi port efi 521 running with p51 heads. i might be able to help.
the victor efi is based on a torquer 2 manifold which takes some port work to use. if you post in the engine tech section scotty J ( the madd porter) can give you details on how to port it to work. what i did is use a trick flow MAFIA dominator manifold. it matches the p51 ports great. it also has pads cast into the manifold for the injectors. they just need machined.
thanks, wayne
