1 - 18 of 18 Posts
Stroker kits are now available at special discounted pricing through December 31st.
Three packages available. ALL PRICES INCLUDE SHIPPING within the lower 48.
KIT #1: $1198.00
Crankshaft: RPM nodular iron (4.140, 4.300, or 4.500 stroke)
Rods: RPM 5140 I-beams (6.700 or 6.800 length)
Main bearings: King standard performance
Rod bearings: King standard performance
Pistons: KB hyper (-20.5cc, -30cc or -33cc dish OEM valve angles only)
Rings: Hastings 1/16, 1/16, 3/16 moly
KIT #2: $1398.00
Pistons: Probe forged (Choice of flat tops -22 or -26cc dish, OEM valve angles only)
KIT #3: $2098.00
Crankshaft: RPM 4340 forged steel (4.140, 4.300, or 4.500 stroke)
-(Lunati 4340 forged crank 4.140 or 4.300 stroke +$100)
Rods: RPM 4340 H-beam or I-beam (6.700 or 6.800 length)
Main bearings: King high performance
Rod bearings: King high performance
Pistons: Diamond forged street/strip (flat tops and dish available with OEM OR Kaase valve angles)
Rings: Diamond 1/16, 1/16, 3/16 moly
Please email, call or PM for substitutions, custom options, alternate parts.
With kit #1 and #2, the 4.140 crank is internal balance and the 4.300 / 4.500 cranks are external.
The external balance cranks can be converted to internal with the addition of some heavy metal, but it would be cheaper and easier to just swap out the front spacer and flexplate/flywheel for external balance parts.
All cranks in kit #3 are internal balance style.
Re: End of year stroker kit sale
KIT #3: $2098.00
Main bearings: King high performance (std, stdx, .001 .010, .020, .030, .040 avail)
Rod bearings: King high performance (std, stdx, .001 .010, .020, .030, .040 avail)
Pistons: Diamond forged (flat tops -32, -36, or -38cc dish, OEM OR Kaase valve angles)
I AM NEW TO BBF & I HAVE NOT HURD OF RPM BEFOR IS THERE A PLACE I CAN LOOK IT UP AT
ALL SO WHAT IS THE DIFFERENTS IN THE H BEAM & THE I BEAM RODS
I ALL SO HAVE A460 HEADS & WOULD WNT A FULL DOME OPISTONS
THABKS
GEORGE
Carl,
I returned from Dallas over the weekend and was very plesantly surprised to find most of my stroker kit had been dropped shipped to me. It was also GREAT to recieve the check for the excess funds.
TOP NOTCH service and GREAT to deal with.
I have not yet received the Diamond Pistons and rings but everything else is as advertised.
THANKS
BT
I AM INTERESTED IN A #3 KIT
WHAT IS THE DIFFERENT IN THE I BEAM & H BEAM RODS
DO YOU HAVE DOME PISTONS PISTONS FOR A460 STYLE HEADS
I HAVE NOT HURD OR RPM PARTS BE FOR
IS THERE A WEB SITE I CAN LOOK THEM UP AT
HOW MUCH WOULD IT BE JUST FOR RODS & CRANK
THANKS
GEORGE
[email protected]
THANKS
GEORGE
[email protected]
-Just a forged 4340 crank and 4340 H-beams or MAXX Pro I-beam rods will run $1245.00 delivered. Differences in the rods can be seen at the website below.
http://www.rpmmaxx.com/
-Diamond A460 dome pistons will be a $150 upgrade if included in kit #3. They will have a 14.5cc dome and H-13 tool steel pins.
Thanks,
Carl
cobra3073 said:
Carl,
THANKS
BT
It was a pleasure to deal with you as well B.T.
Thanks for your business!
Well Carl, "BROWN" just left me with the rest of my order - - what a day!!
Again I cannot begin to explain how much I appreciate your responsiveness to my questions and your business attitude. I offer my SINCERE THANKS to you and the other vendors on this site (with whom I have dealth). You guys are GREAT!!
BT
I WENT TO THAT SITE
IT DID NOT TELL WITCH ONE WAS THE BETTER ROD
DO YOU KNOW
WITCH 1 IS THE LITE ST
AND
WITCH 1 IS THE STRONGEST
WNST ABOT TITAMUM RODS
HOW MUCH DO THE WAY WHAAT DO THE COST
Discussion Starter #12
GFPRACING said:
I WENT TO THAT SITE. IT DID NOT TELL WITCH ONE WAS THE BETTER ROD. DO YOU KNOW?
WITCH 1 IS THE LITE ST AND WITCH 1 IS THE STRONGEST?
WNST ABOT TITAMUM RODS? HOW MUCH DO THE WAY WHAAT DO THE COST
They are both good rods. They will both handle about the same power, but the I-beams are lighter and better suited to higher rpm applications.
The Ti rods are not available in lengths that will work with these kits, and they run about $3500.00 a set.
Discussion Starter #13
Lunati 4340 forged cranks now available in kit #3 for +$100.00. (4.140 and 4.300 stroke only)
Discussion Starter #15
Free shipping through 12/31/08! :shock:
Discussion Starter #17
Last chance before new 2009 pricing takes effect.
4.3 STROKER kits
Hey Carl, got my RPM nod iron 4.3 crank,, 5140 6.8 I-beams, and the Diamond pistons, are frickin beautiful. very fast shipping , plus the year end ,, free ship ,, was the bomb,, seriously. thank you very much Rick.
1 - 18 of 18 Posts
