Enderle Bird catcher, 2 stage fuel injection, 110 pump with 3 way shut-off valve. Setup is 1 year old with very little use. Comes with pre-bent lines for tunnel ram intake and into heads. Was setup for 642 a-head motor.
This is what is included:
(1) 110 enderle pump with 3 way valve
(1) bird catcher
(1) mounting bracket for bbf
(1) gilmore drive belt
(1) gilmore drive pully for crank
(1) gilmore drive pully for pump
(1) barrel valve with bypass & lines to distibution blocks
(2) distribution blocks with bypass valve
(8) pre-bent lines to a-460 tunnel ram intake
(8) pre-bent lines to a-460 heads
(8) flexible hoses to a-460 heads
(8) down nozzles
(8) intake nozzles
(8) e22-31 jets
(8) e12-24 jets
(8) e34-39 jets
pills from 60-120
asking $1500 for entire setup
Thanks,
Ron
330 466 8808 after 4pm
