1 - 6 of 6 Posts
Complete Enderle Bird type Mechanical Alcohol injection with airfilter and fuelpump
Comes with Barrel valve and throttle linkage, distribution block and stainless injection lines and inject nozzles
80A fuel pump and shutoff valve
You can buy it with or without Aluminum tunnelram for A-460 heads
nice CNC adapter plate from intake to birdcatcher and a spacer plate
Came off a 600 cu in combination
$950 with airfilter and fuelpump without Intake and adapter plate
$1200 for everything
Let me know here if need more info
Enderle injection
do you still have it and what kind of fuel pump setup do you have belt driven or cam driven?
Best offer on Intake
Water crossover was blocked off and a external crossover was used.
The t-stat neck has been removed so a large distributor or Mag could be used.
1 - 6 of 6 Posts
