1 - 7 of 7 Posts
520ci ford engine consists of:
4.140 forged crank
4.470 bore bill miller gas ported and coated pistons (14.5:1 cr)
Blue Thunder "B" heads ported and polished by Engine Systems
6.8" oliver billet rods
Weiand tunnel Ram with either dominator or 4150 carb top
Crane solid roller cam, gold roller rockers, roller lifters
MSD billet distributor
BHJ balancer
rollmaster timing chain (double pinned)
Engine is set up for pulling; runs very consistent (had 4-wins and several top 4 placings this year). $8,500 obo (used chuck nuytten dom. carbs the last few years) SOLD
Chuck Nuytten alky dominators old style carbs, very consistent for tractor pulling $1,500/pr obo(will only sell if engine sells first) SOLD
Product engineering pump/filter combo with 4-port regulator $500 obo
Predator alky carbs, converted by Predator $600/pr obo
Blue Thunder "B" heads (ported by Engine Systems)w/ Weiand tunnel ram intake (either 4150 or dommy top) $2,000obo HEADS SOLD, INTAKE PENDING
Browell Bellhousing for BBF 8 1/8" with inspection holes and liner; starter pocket, cross shaft, throw-out bearing, and candlestick. Can be re-certified $1,250 obo(will only sell if engine sells first) SOLD
Titan BBF 2-disk full pedal slipper clutch. 1 3/8-10 spline. Brand new disks, floater and friction surfaces (flywheel and pressure plate) 4 passes ago. Clutch has starter ring. $2,000 obo.( will only sell if engine sells first) SOLD
Hays BBC 2-disk full pedal clutch. 1 3/8-10 spline. Has billet aluminum pressure plate instead of stamped steel. $1,000 obo
SCS twin countershaft single speed transmission with reverser 1.217 headset and has a 1.150 quickchange set. $3,000 obo also includes (1.083 quickchange set)(will only sell if engine sells first) SOLD
Sparky's Revenge chassis, pics can be seen at indmpa.com. Cockshutt 50 rearend, hydraulic brakes, needle bearing cross in differential, roll cage, aluminum fenders, wedge frame, direct drive (no tractor transmission) $5,000 obo SOLD
call or pm with questions
Mike
574 702 1234 after 5pm, anytime on weekends
Discussion Starter #2
prices reduced
The bold priced items are the ones I lowered the prices on.
If you see something you are interested in make a reasonable offer.
Mike
1 - 7 of 7 Posts
