Selling a 466 BBF mild race engine. Was used in bracket racing with minimal maintenance and is a great backup, starter, or street motor. Here are some of the specs.
Dove A block
Victor Jr. Intake (matched to heads)
A429 Aluminum Heads (matched to intake)
Ford Racing Valve Covers with Baffles and Clamps on Breather
Roller Rockers
.585 Hydraulic Cam (reason for minimal maint)
12.1 compression Probe Pistons
Eagle crank (stock stroke) and Eagle H rods
Timing Chain
Mechanical Water Pump with Electric Moroso Belt Drive
Standard Ford HEI distributor
Powdercoated front motorplate
Rear Sump 6qt Oil pan
Header Bolts
Jegs High Compression 18.1 starter
Engine roughly makes around 625hp. The only thing needed to make this engine complete is a flywheel, plug wires, carb, and headers.
My 1/8 mile passes were consistent 6.1's 110mph (1/4 times were 10.1 135mph) in a 2800lb '03 Mustang 25.1E Double Frame Rail with a glide behind it with a 4.56 rear. I CANNOT remember off hand my 60' times because I have sold everything, but if I am correct it was around 1.3 - 1.4. The engine is making about 625hp.
I will also include a brand new engine picker and the black engine cradle (with wheels) that the engine is on now with the purchase. Engine has been stored in a seal tight temp controlled room, so NO outside variables to mess with it.
Just to let anyone know who is interested in the motor, it was built by Senior Member QtrWarrior. Anyone that knows him or his team, they build solid products. If anyone has any questions, and I don't have the answers, he's got them.
WILL SELL ENGINE, HOIST, AND CRADLE FOR $3500. CALL ANYTIME 912-856-5567 OR EMAIL ME HERE OR AT [email protected].
Dove A block
Roller Rockers
Timing Chain
Header Bolts
