Hey everyone, I was given an Erson cam but dont have the spec sheet and haven't been able to find any online. I was wondering if anyone out there could help me out with this. The part no. is E260223 and the grind is TQ50H.
Super Moderator
You will find what you are looking for in this .pdf. Below is a description of your cam.
High-lift, dual pattern. Needs 4-barrel, headers and lower gears. Works best with stick or high-stall automatic. Strong top end camshaft. Rough idle. Should have at least 9:1 compression ratio.
Special design camshaft for jet boat
Here is where the rest of the info is:
ftp://ftp.mrgasket.com/GUESTDOWNLOAD/G_NUMBERS/74223G.pdf
Hey man thanks a lot! I looked everywhere for that info. It sucks that I won't be able to use it tho.
