I am just wondering about how much HP or torque my build for my foxbody will be putting out.
Specs are...
460 .030 over (466) and balanced
Ported/polished C9VE heads 2.20 intake/1.75 exhaust
Approximate compression- 10.7
Comp cams 270H (.519 lift)( debating on going larger)
1.7 roller rockers
Hooker Super comp headers
Torker 2 intake
Holley 750 DP
I will be running C4 with a 2500 stall.
Any thoughts anyone?
Specs are...
1.7 roller rockers
Torker 2 intake
Holley 750 DP
400~
Guess-timate on HP and Torque output?
400? I was hoping possibly a little higher.
With a stock 69-70 429 being in the 350+ range.
Higher compression, ported heads, larger cam and tubular headers should help bring it up more than that shouldnt it?
Surely someone has built a similar engine combination.
Any ideas on the amount of torque this combination might have?
I would think 400 would be darn close. The carb and cam are limiting you big time. Put a FRPP C460 cam in it and a QFT 950 and you would be closer to 500hp. And are you sure on the 1.7 rockers? Because stock 460 rockers are 1.73 so using a common BBC 1.7 would lose HP.
