1 - 9 of 9 Posts
The way I see it, if an OEM is not using it or suggest you buy it, likely it doesn't work or is detrimental to engine life, performance, etc. OEMs are struggling to meet CAFE regulations even to the point of selling high mileage vehicles at a loss. So, if there was some magic cureall for gas mileage, I'm sure they would give it a try and use it if it worked.
If it really worked as advertised, one of the gasoline companies would buy the patent and use it in their products and advertise the hell out of their amazing gasoline that outperforms all other brands. SOMEBODY would be making millions off this stuff and giving it more than a cheesy website.
May as well save some $$$ and just go to the local hardware store for some acetone. It's been used with mixed results to get better mpg. The bad thing is that it's paint stripper, so don't spill it on your car and it's not good for the rubber fuel line and stuff. Lots of info on the web about it. If you feel like experimenting, you could try the other environmentally friendly ester paint thinners/strippers, which is probably exactly what this product is.
gas saver
But wait we will double your order and when you run out we will ship you free a life time supply all you need to do is pay for shipping 8) Gregg
and handling... Don't forget the handling.
Anyhow, these types of things most likely are one form or another of alcohol. Need to run richer to burn at the proper ratio (like E85). Hurt MPG, or just causes you to run lean. For such a small amont it likely does nothing. Best bet for MPG is to just jet lean as possible, and enlarge PV passages if needed. Drive sensibly, overdrive helps.
Or do like me. Work a mile from home, and ride a motorcycle in the summer. Most of the gas I purchase is for pleasure use, not necessity. Beats past jos, driving 70-80 miles each way every day.
what an idiot. His whole premise went south as soon as O2 sensors and computers got involved in cars. This manages the air/fuel based on excess O2 in tail pipe emmisions.
He is right on on thing, the internal combustion is highly inefficient. but most of the energy is wasted in heat.
S
Guest
My guess is it's MTBE.. Lol they added it to fuel to raise octain then the goverment took it out clamining it would cause canser and damage our well water. That's a totally different topic..
That's what I think it is..
Laters!
1 - 9 of 9 Posts
