1 - 6 of 6 Posts
· Registered
Anyone ever compare the two heads thier flow rate and port shape and chamber shape sure look very similar.
Anyone have the details of the EX514 heads? valve angle,cant,and what not.
ex514
Watch Automotive lighting Automotive tire Rim Gas
afr
Automotive tire Locking hubs Hubcap Bicycle part Rim
afr
Photograph Wood Rectangle Automotive exterior Material property
ex514
Automotive lighting Fixture Gas Auto part Automotive exterior
· Registered
Discussion Starter · #2 ·
And anyone learned any tricks for the AFR 295 heads?as far as improvements.porting,and what not best intakes to run with them.
When i put my motor together there was not a lot of information out on there actual performance,
mine seem to work good ,never seem to run out of steam.
· Premium Member
Their CNC program is pretty good.
The 315's are better at higher lifts.
You will find gains just below the carb pad by addressing the short turn radii into the runners at the roof.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
· Registered
Discussion Starter · #4 ·
Custom ground cams
R-H-P.biz
(253)-988-6648
thank you very much for the insight thats what i was looking for.
Salute.
· Registered
Discussion Starter · #5 ·
Custom ground cams
R-H-P.biz
(253)-988-6648
I am completely unaware of any of the short comings of the intake.
Could you unpack your assessment, of the issues concerning,the short turn Radii
· Premium Member
Short turn = transition from carb pad to runner at roof.
Dommy flange is pinched.
Custom ground cams
R-H-P.biz
(253)-988-6648
1 - 6 of 6 Posts
