1 - 7 of 7 Posts
So true, so true. But then again this is 460ford.com?? All jokes aside, I have a set from a 70 429 and a set from a 78 460 and a few "singles" from different take off heads. Yes, Bronco's! I restore and do custom 66-77 bronco's.
Both manifolds were in trucks. Started to toss them out but figured someone might need them.
broncoman, the cost of swap headers is holding up my junkyard/napa zephyr swap. i wonder if any of the truck manifolds lend themselves to fox body use? the ones on the lincoln donor car i had were cracked. (i assume caused by lean/hot exhaust tempertures from the crappy 4 barrel carb).
....perhaps when you have some extra thinking time, lol. thanks in advance, bob netherland.
I got a set of 73 LTD 460 exhaust manifolds you can have - I am in the Houston, TX area - not sure about the Fox application -
1 - 7 of 7 Posts
