1992 F-150 Pickup Short Box Roller $6,000 over $15,000+ invested!
Chassis Front
Competition Engineering 90/10 front shocks/2’’lower drag springs w/3” drop Beltech beams
Set up for BBF motor plate with mid plate custom firewall/motor setback
Flaming River steering shaft coupler to manual steering box
Engine limiter mounts (2)
Rotors modified for 4-3/4” bc Wilwood Master cyl.
Chassis Rear
Dana 60 with spooled 4.10 Strange 35 spline axels 5/8” studs
T/A aluminum carrier brace Strange 8 position coil overs
Adjustable Competition Engineering ladders Strange moly drive shaft (negotiable)
Strange 11” disc brakes
Wheels
ET Fronts 29” on 4x15 Convo Pro 4-3/4 bc S&W 10 pt cage 8 pt installed
ET Streets 35x14.5x15 4-3/4 bc 10.8 tread on 10x15 Convo Pro centerlines
Cooling
True Cool radiator with 16v fan Trans cooler
Fuel System
Magna Fuel Prostar 300 and regulator 10 an fittings to regulator, 8 an to carb
16 gallon fuel cell
Electrical 16v. system
All Autometer ultralight gages with white face MSD 6AL
Hurst line lock Trans button
Painless pro switch box w/Painless relay/fuse panel
Headlights/horn/directional/brake lights – new 16v XS battery
Interior
Tilt steering 2 race seats both with/5 pt Simpson harnesses
Exterior (Black)
Mint body – no rust
Fiberglass Lexan rear window
• front bumper
• rear roll pan
• 4” cowl Cervini hood
This truck has seen 40 passes; not street driven; all professional workmanship; Wisconsin titled. This vehicle with a street engine can be driven on the road safely and easy on the wallet. PM ME IF INTERESTED FOR PICS AND CONTACT INFO ELKHORN WI. TOM
