1 - 3 of 3 Posts
Weiand tunnel ram, semi port matched, needs some finishing work. is drilled and tapped for fogger nozzles. NOS sportsman fogger system plumbed and installed (jets included, no bottle or feed line), pair of holley 660 center squirters in good running condition $1200 OBO
C-6 trans, deep sump pan, B&M shift kit and unknown brand 3500rpm convertor. $250 OBO - MUST SELL ENGINE FIRST
460 long block assembled and running in car as of yet
DOVE 2 bolt thick main web block with main girdle
factory 460 crank standard rods and mains internally balanced
clevite main, rod and cam bearings
Eagle H-beam rods with 1.040 floating pins
.030 SRP forged flattop pistons 1/16, 1/16, 3/16 JE moly rings, file fit
Melling M84DHV oil pump and shaft
Canton fox body oil pan and pickup
7 1/4" fluiddampner
factory flexplate
all felpro gaskets, 1018head, 1812oil, 1231intake, 2712 RACE
cloyes 3 keyway dual roller timing chain
factory timing cover
factory distributor w/ bronze gear
stock waterpump w/ moroso electric drive
C9VE iron heads ported with 2.25/1.725 Ferrea stainless valves
Manley 3/8 guideplates and .080 moly pushrods
ARP rocker studs
ARP head studs
Crane Gold 1.73 roller rockers
Crane rocker stud girdle
FRPP tall aluminum valve covers
steel 10* retainers and keepers
K-motion k-1000 roller valve springs
Comp Cams roller .726/.728lift. 254/262 at.050 duration. 110 lobe seperation
Comp Cams IDM hole roller lifters
Hooker fox body headers
Accel 300+ 8.8mm spark plug wires
NGK spark plugs
fabricated solid fox engine mounts
factory starter (big heavy one)
has about two hours of run time on it, 45 min was break in
$4200 OBO
this engine is in the car and runs, with above mentioned tunnel ram and C-6. Will make a package deal for everything in the ad. open to offers. pics available.
I am listing this for a friend, I assembled the engine, and ran it for break in, it is very healthy. It's been up and down the road half a dozen times since. He now needs money...
told him to get rid of the woman instead.
If you have any questions I can probably answer them and can also get you in touch with the owner. Thanks - Dave
the headers are in good shape, maybe four years old with nearly no run time, but it all needs to go as a package. If you can find someone that wants the longblock, I'll work out something on the headers.
Dave
1 - 3 of 3 Posts
