1 - 3 of 3 Posts
D1ve block filled to bottom of water jacket. 2yab offset crank -10. Groden aluminum rods with ross 4.440 pistons with hellfire ring package. Cam motion custom grind cam. Dur @.50 267/ 274 Valve lift 740/ 726 Lobe sep 110. The main, rod and cam bearings are all coated. Main and rod bolts are Arp. Also Arp oil pump shaft. Melling HV pump. Main girdle, dual edelbrock roller timming chain.
I just sold the parts off this motor on another post. This motor was in a 3100lbs mustang. Has 21 1/8 mile passes and ran 6.30's on motor. Oil preassure is a steady 80lbs
If you have any other questions, please ask. Thanks $2,400
1 - 3 of 3 Posts
