1 - 11 of 11 Posts
429 BBF ,DOVE-C heads,Stealth intake,D1 block,C9 rods, standard bore with new hone and black moly sealed power rings, new crank turned .10/.20 new clevite race bearings, new comp cams double roller chain,new gaskets throughout , compression is around 11.5.1, new procomp distributor, new chrome covers,general kinetics camshaft, 296 adv .560 lift on a 108 sep ,
hi volume melling pump with canton pickup,Canton 8 qt fox swap pan,ford motorsport mounts,and hooker supercomp swap headers 2" primary and 3.5 collector. brand new water pump, , new mini starter, everything on the motor wich is not new has been checked out and cleaned before reinstalling it. 14x4 k&n filter on drop base to clear hood , new affco aluminum radiator 31x19. and 3,000 cfm cooling fan. doesnt run hot.
it hold 70-75 psi cold oil pressure at idle and 65-70 when hot
[TRANS]
C-6 good trans recent rebuild and new converter that stalls in the 2,000 range. new trans cooler.newer mount has leak around converter area i have yet to check out it has new seals throughout. shifts good and firm
also have drive shaft with new spicer yoke,
asking 2,000 obo it is located outside chattanooga tn.
dont be afraid to make offer im trying to get my old torino back!!
1 - 11 of 11 Posts
