For sale, tko 600 faceplated by promotion powertrain. Gears 1-4 are faceplated 5th and overdrive are not. 26 spline input shaft. Comes with polished promotion shifter. Low miles, most miles are from chasis dyno. Asking 1800 plus shipping
thanks
Trans can be drove on the street but is made for track use. When a trans is faceplated all the synchros are removed and replaced with a ring that has only about 6 big teeth (slider also). You can shift it at real high rpm's without lifting on the gas pedal. The trans isn't real good for the street that way though. It grinds and is hard to downshift also. Most people would hate it in a street only car.
Located in Dothan Al. 36301
