1 - 8 of 8 Posts
Fan clutch problem
Hello, I'm restorating a Lincoln Mk3 in France.
I'm Looking for a thermic fan clutch.
I only foud some 3 and more height. Too lengh.
The references gived in the past posts are no more accurates.
I need somme help for a réference.
The car has been repared with a static kit, so the water pump hs, so head gaskets hs... I have rebuilt all this, clened, new paint, a lot of work, but now i'm bloked.
Have you tried here?
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Log In or Sign Up to View
Check out the Hayden #2765 fan clutch. I use it on my cramped 502 57 Ford. It's the shortest one I've found and has the same bolt pattern as original.
Discussion Starter · #4 ·
Custom ground cams
R-H-P.biz
(253)-988-6648
Tank you, I keep this site in mind.
The Hayden 2947 is the lowest profile one you can get at 2.7". The studs have to be trimmed to fit and it can be a bear to get the nuts on but if you don't have the space it works.
That one is also a good choice. Could be a better choice as 2947 is listed as Heavy Duty and the 2765 is listed as Standard Duty. Yes, the nuts are a bitch to get on.
Discussion Starter · #8 ·
Y bought the 2765 but now i'm bad with the fan. I hesitate betwen adapt it or looking for a new one that feets well.
Have you the ref for the fan. Mine is 48.5 cm diameter ( 18.9 P).
1 - 8 of 8 Posts
