1 - 18 of 18 Posts
Just wondering how fast people have been with a stock stroke 460 using factory head castings on motor. Post up what you have in your garage or what you have seen at the track.
What's a "factory head"? Iron? Aluminum? Factory valve locations/angels? Available for purchase from Ford? D0VE/D3VE? DO0R-E? A429? SCJA? C460?
:confused:
A couple months ago, this T Bird went 9.13 @ 145 (5.79 @ 119 8th). 466 with ported D0VE heads. Runs on 110 fuel.
Wow! That's hauling ***! I have a '93 Mustang that has been 6.24 in the
1/8th. It is a stock crank, stock casting headed 0.060 over 460. I am very happy with how fast it is on its first season out. I have a few more things I need to do to get a little more out of it. I think a 5.99 would be awesome!
3100lbs 10.19
DOVE heads
460ci N.A.
stock pistons,rods,and crank
and std bore,4.360
stock
i pulled a motor out of a 70 lincoln put c8ev heads on it and a victor manifold with a 950 carb and went 11,os ....was a fun ride.
Stock block, arp main bolts, stock crank, stock rods w arp bolts, probe flat top pistons .030 over, fully ported dove-a heads, victor intake, 1050 carb, custom grind roller, powerglide trans, runs 630s all motor been 5.55 in the 1/8 mile single fogger w progressor in a stock suspension fox body on 28x10.5s weighs 3040 lbs race ready. Hoping to go faster now with more nitrous.
pump gas D3 headed 429 in my 4600 pound Montego....best of 132 mph so far.
This car has seen a best of 9.02 @ 148 with the 466 in good fall air last year. It's going quite a bit faster now, but we put in a bigger motor this year.
It's a tube chassis car originally built by Alston Chassisworks then redone by Steve Everett (Steve1071 on here). Steve also built the motors for it. Trans is a 1.76 glide and gears are 4.56. The car weighed 2280, no driver with the iron head 466. It now has a 557 ci 4 bolt main D0VE block with extensively ported Edelbrock heads (bought them from Bruno at the other site). We tested last week and ran 8.60s but the motor and suspension needs some tuning.
Good luck with your build! I'm a big fan of T Bird race cars.
I have a friend in North Carolina with a 3200 lb mustang (fox) with .060 over 460 a 4150 carb, glide and 28x10.5's going 5.80's n/a
1 - 18 of 18 Posts
