1 - 16 of 16 Posts
I have for sale new in boxes Ferrea 5000 series intake and exhaust valves that are 2.25 / 5.271" intake and 1.76 / 5.060" exhaust.
great for Dove-C, D3ve, cobra jet or police intercepter heads.
$160.00 shipped to your door!
are these valves std length?will they work in the D30E heads as a replacement valve?if so i am interested.
Larry T these valves are +.100" longer than the stock valves offered in the 73 and up castings.
they would work but with modification ie spring pad spacers or a combination of spacers and -.050" locks or perhaps targeting a spring intalled height of around 1.900. i do believe the stock heads have a 1.800" installed height.
probably would be easier and cheaper in the long run to get the correct length valves.
i have a set of Cj heads would they work in those?i dont know the year of the cj heads though.then again i dont know which head is the better ones to use D30E or the Cj?
if you have cj heads, i'll go with them. these valves are the correct length for cj heads.
the cj heads will increase your compression though. you may consider that if you're wanting to use pump gas.
ok i just found out that i dont have the cj heads.....what i have is early 69-70 429 heads in stead of the cj"s.if the valves wont work in these then pass them on to the next guy.thank you......
Larry T you have the early heads either c8ve, c9ve or d0ve. these valves are the correct size for them as well.
i would use these heads above the d3te heads that you have. only thing again is that the combustion chamber is around 76cc and will raise your compression about 1 point above the d3's.
thats fine about the 76cc's its a race only motor,so i need the hi cr.i will take the valves if you havent all ready promised them?do you take paypal?if i will need your pay address.
Discussion Starter #15
they will be shipped out tonight!!!
yeah that's right tonight as kinko's/fedex stays open 24-7 in my area!!! 8)
besides i have to go out to blockbuster anyhow. my children want some dvd's. lol
1 - 16 of 16 Posts
