1 - 11 of 11 Posts
Due to some issues I need to sell my back up shortblock.
It is a C8VE block with a stock crank, Ohio Crankshaft H-beam rods, SRP Flat tops, Childs & Albert ZGS rings and Federal Mogul race bearings. The oil pan is a Hamburgers deep sump pan the oil pump is a shimmed CJ pump with a ARP shaft and it comes with a CJ Balancer. I put about 800 miles on it and when I pulled it, it was holding 70 psi oil pressure at start up and 40 when warm and idling. One thing might make a difference to some people is that the pistons are about .009 out of the hole. I used .052 gaskets with no issues. It's been greased and covered up on a engine stand. It does not have a camshaft ot timing set I'd like to get 1,300 out of it but will consider reasonable offers.
The motor is in the northwest / north central part of Ohio...
Bump photo added
I also forgot to mention that it comes with a flex plate. I've dropped the price to $800 or best offer + shipping if need be.
I'm also throwing in the engine stand as an incentive.
Looks like a darn good deal. If only I hadn't already built my short block and spent FAR more than $800 on it... just need to build a time machine now! Good luck on selling it.
1 - 11 of 11 Posts
