1 - 9 of 9 Posts
Part # 51699 - grind # 16-ur49-ur53
308 - 318
277 - 286 @ .050
.427 lobe with 1.73 rocker lift is .738 both sides
110 Lobe sep
106 center line
ex valve closes @29 ex valve opens @77
in valve opens @32.5 in valve closes @ 64.5
sold
Cam Specs.....
1st, you have a p.m.
2nd, I looked up the part number you listed and the specs are as follows:
Intake / Exhaust
Dur @ .050 = .280 / 284
Lift @ 1.73 = .772 / .756
Lobe sep 110
Intake centerline 106
The grind number doesn't match the part number.
Could you have one of those numbers listed incorrectly?
Thanks.
cam
Intake / Exhaust
Lobe sep 110
Thanks.
i posted what it says on the cam card, i checked the part number its 51699 ,the specs are correct its a .427 lobe lift on both sides , i also got on lunati website that number did come up with what you said . i guess the grind numbers mean more than the part number.
thanks
Cam specs
Ok, thanks. I didn't know you were quoting from the cam card. This is a good thing since the specs. on website were a little aggressive.
1 - 9 of 9 Posts
