1 - 6 of 6 Posts
ford 460 motor aluminum sold
ford motorsports 460 short block for sale includes block, crank,rods,pistons freshly asemboled by fowler engines in columbus ohio . started as crate motor then it was dis-assembled tanked , honed new rings and bearings,and re-assembled . has forged flattop pistons (trw) cj rods (football bolts) .this short block has not been run since it was gone through .bullet solid roller cam + lifters.crane rockers,ford motorsport valve covers,aluminum cj heads a-429 ported by fowler engines from above short block ready to go with roller springs .edelbrock victor intake port matched to the heads above 4150 flange.sfi balancer, aluminum water pump,melling hv oil pump and rear sump oil pan, ready to go should make approx 650hp e-mail [email protected] for more info located in columbus ohio $4000
SOLD
just under 11:1 cr. it started as a ford motorsport 460 cj (not scj) 580hp motor. that was with the hydrolic cam and no port work.
thanks, wayne
it is 2bolt main but I have a std bore 4bolt main cj block coming in the shop at the first of aug.
wayne
1 - 6 of 6 Posts
