1 - 7 of 7 Posts
I have a 460 motor that has DOOE-R heads,Performer RPM intake, Edelbrock 1407(750cfm) carb, D1ve block, roller rocker arms, and Ford motorsports valve covers. Bore is around 4.390 and stroke is around 4.150. The motor was out of a 69 ford pickup and I was told it had a bad valve. I checked the compression and the cylinders on the passenger side have 175lbs but two cylinders on the drivers side #5 125lbs and #7 25lbs. I removed the head and found on #7 cylinder a small piece of piston broke off down to the ring on one side. As far as I can see the cylinder and head looks good. It looks like the valves need checked on the drivers side. I have the motor listed on Craigs list but I would be willing to part it out if anybody is interested.
Thanks, Kim
Auction Block Rules
1) You MUST state your price in the ad
2) You MUST state your location
3) No links to Ebay ads. If you want to sell it to forum members, list it here.
Sorry I did not get back to you guys. I had computer problems. No power.
I'm in McCall, Idaho and I would like to get $1800 for everything.
1 - 7 of 7 Posts
