Engine Systems/Ted Fischer prepped C460 heads, dyno pulls only since freshened, flow 490in 380ex, (Ted's 615inch test engine made 1190hp with these heads), matched C460 single four intake, WW 1.8 shaft rockers, pushrods, new Cam Motion 936/860 roller camshaft, Comp Cams z-bar roller lifters with dyno time only, new never run JE 4.628 C-head pistons, Crower 6.700 billet rods with dyno time only, Scat billet 4.500 crank with 60-65 passes, used never broken 4.600 bore A460 block with roller cam bearings, bushed lifter bores, O-ringed, and main studs, C-head bolt set, used sheet metal valve covers, new Hamburger full length chassis style sheet metal oil pan with pickup, $10,000 for everything. The above BBF components are as I have described. (This is not a complete assembled engine) Thanks Jim (901)268-6348 e-mail [email protected]
