1 - 20 of 24 Posts
Guys I have a stock offset ground Crank that's 4.142 stroke that I need to move. It was $350 to grind it a few years back but Don't need it now
SOLD
Ace
Was it ever used or raced after being ground?
Raced before it was ground, or just out of a core motor?
2Y or 3Y?
Big pilot or small?
Any flash rust or anything on the journals?
Do you know the weight, or approximate shipping to a business @ 39667 ?
Ron
I have to check & make sure this is the right one for the pistons I bought on here a good while back. & I'll check with my cousin on freight by truck (if that is an option).
I'll let you know something.
Well that is how my luck runs. Just got home & both sets of pistons are either for a 4.3 stroke or a stock 460 stroke. I really had my hopes up. Maybe next time. Thanks for your patience
Ron
Discussion Starter #17
Just wondering why is it better than a scat or eagle cast crank?
Sent from my M886 using AutoGuide.Com Free App
I have had scat 9000 cast cranks and had seen to (2) many failures where as I use to run nothing but offset ground FORD 460 cranks and have never had one fail yet. I have one in a 514 that has been running of over 12 years. I'm wanting to built a 572 -598 and will put this (514) on the shelf for a back up motor
Ace
Discussion Starter #19
The gentleman called me to day to say he had unexpected circumstances come up and would not be able to swing it this month.
So back up for sale
Ace
1 - 20 of 24 Posts
