1 - 20 of 25 Posts
I have a balanced rotating assembly. If you buy the whole thing you get scat crank, grp rods, diamond pistons, bearings and rings for $3200. I am willing to split up the crank rods and pistons.
New 4.150 scat forged. I paid $1100 sell for $950
New grp 6.8 5000 series aluminum rods paid $1085 sell for $900
New diamond a-460 pistons for 4.53 bore 12.5cc domes .043 rings gas ported, h13 pins, total seal .043 .043 3mm conventional top with napier second piston rings with a 11# oil ring. Pistons were $1200 and rings were $275. Sell both together will not separate $1200
Have a new bearing set of std clevite mains and 2.20 pinned rods. $250
D9te 2.2 rod 3.68 stroke forged crank. $375
Used Msd digital 6, billet small cover dist, hvc coil. $350 Will split the dist from the digital 6. But the coil goes with the dist. $200 for the digital 6. $150 for dist and coil.
Have canton fabricated valve covers new in the box $200
Canton windage tray new in the box with main bolts for mounting $100
Comp cams 836-16 lifters new in box $350
interested in the dizzy and coil, you got the part# and a pic or two? what condition is it in?
thanks ralph, you can text the pic if its easier
562 234 7986
The Msd stuff and the comp lifters are sold. All the rest of the stuff is still available. I am negotiable.
Interested in in the valve covers. Will they fit stock type heads and clear roller rockers?
Sent from my Milestone X2 using AutoGuide.Com Free App
Discussion Starter #14
Any one need crank rods or pistons? $900 for the crank $875 for rods $1100 for pistons and rings.
1 - 20 of 25 Posts
