1 - 16 of 16 Posts
ROLLING, AS IN NO ENGINE,TRANS,NO CENTER,
EVERYTHING ELSE GOES,INCLUDING BOSS 429 HEADERS,MOTOR PLATE.
CAN BE BOUGHT MANY MANY DIFFERENT WAYS, WITH A CENTER,WITH A TRANS,WITH BOSS 429 HEADERS,
CAR WILL COME WITH........
FRESH TIRES,BRAKES,
ING BOX.
SHIFTER
DRIVESHAFT
CAR JUST UPDATED NEW LEXON,NEW CERT ,NHRA TAG, NEW FUNNY CAR CAGE,
NEW FUEL CELL
NEW CELL TRAP (FILL) DOOR
NEW ING. BOX
HURST SHIFTER
NEW URT. LITE AUTOMETER
CAR IS AVB WITH ANYGEAR RATIO YOU WANT
RECENT 14X32 M/T TIRES
AERO SPACE
AUC-U-SUMP OIL SYSTEM WITH ELECT VALVES
MALLROY
WELD WHEELS,PLUS SPARE REARS, 15X15'S
DRIVESHAFT
TRANS COOLER
REMOVABLE WHEEL, NEW BELTS
NEW WINDOW NET
ALL LIGHTS WORK,BUT TURN SIGNALS
CAR HAS.............
GRIFFEN RAD W/ FANS
WHEELY BARS
CHUTE
4 WHEEL DISC
REAR WING
WELD WHEELS
KIRKEY SEATS
NEW VFN NOSE (HEADER PANNEL)
NEW FRONT HEADLIGHTS,
PROSTOCK SCOOP
LIFT OFF HOOD
HEADERS ARE OUT BEING COATED RIGHT NOW
CAR SET UP FOR BOSS 429
K/MEMBER
TUBE CONTROLL ARMS
LITE WEIGHT HUBS,AND FRONT BRAKES
STOCK FIREWALL,AND FLOOR
CLEAR TITLE.....
LINE LOC
BRAKE VALVE
4 LINK CAR
NEW STRANGE STRUTS FRONT
NEWSTRANGE REAR SHOCKS 6 PASSES
THIS CAR COME WITH EVERYTHING,BUT ENGINE!
THIS CAR DOES NOT NEED PAINT,OR TIRES,OR WIRING,FUEL LINES,NOTHING....
HAS TRUNK MOUNTED N.O.S. BOTTLE BRACKETS
WAY MORE AND TOOO MUCH TO LIST,
E MAIL ADDRESS FOR PICS,
thanks,want to post a pic or 2 for me?
car hooks hard,and goes straight!!!!!!!!!!!!!
19,5000 for everything but engine and trans
Posting a few pics for BOSS 429...ENJOY!
YUP FOR SALE AS ROLLER,
NEVER WRECKED,
CAR SET UP FOR 10.300 DECK BB FORD ,AND C6 TRANS
FRESH TIRES,BRAKES,
ING BOX.
SHIFTER
DRIVESHAFT
NEW FUEL CELL
NEW ING. BOX
HURST SHIFTER
AERO SPACE
MALLROY
DRIVESHAFT
TRANS COOLER
NEW WINDOW NET
GRIFFEN RAD W/ FANS
WHEELY BARS
CHUTE
4 WHEEL DISC
REAR WING
WELD WHEELS
KIRKEY SEATS
PROSTOCK SCOOP
LIFT OFF HOOD
K/MEMBER
TUBE CONTROLL ARMS
CLEAR TITLE.....
LINE LOC
BRAKE VALVE
4 LINK CAR
AND THE LIST GOES ON
30,000.00 OR BEST WITH EVERYTHING,OR
LESS MONEY= LESS PARTS
Powered by phpBB © 2001, 2005 phpBB Group
this is one nice car for sale we did the 25.5 update, new lexan windows,and window net this spring this is not your normal dragcar it has alot of thought and time dedicated to it very nice. thanks judd JRC PERFORMANCE
thanks for the kind words all of you........
there is a sale pending,i hope it goes thru,the car will still be close to home.
CAN DELIVER?????????????????????????????????????????
this car just needs your engine,trans, ill install a center, the 429 hooker headers will go right in,and for a little extra ill include the boss 429 headers, this has been a great car,been in pop hotrodding, twice center fold car, hot rod did a shoot on the car, been in fabulous mustang and ford mag,
thanks
Discussion Starter #12
for everybody ordering boss 429 heads, heres a car guys, with a set of step headers, for a boss 429 hemi
partial ford trades?
engine part trades?
i need a tall deck alum 429 block, must hold water
Discussion Starter #14
WILL TAKE TALL DECK ALUM 429/460 BLOCK IN TOWARD TRADE AND....
AR BOSS 429 HEADS, TALL DECK INTAKE???????????????????
Discussion Starter #15
theres a lot of thought in this car,flat as a person can make the floor pans,frame rails high for ground clearance,mufflers,alum duct work under rear of car,this car scales out perfect,theres hours just in the trunk lid hinges,because of the wheel tubs, steel tubs welded in, a real unie body drag car if there ever was, equil lenght step headers, this car went 8.70s 161 thru the mufflers w/tail pipes, and always goes straight,and stops great too.
car is wired,plug into you dist,or crank trigger,coil,has auctusump in cowel,ready to hook up to engine,trans cooler in mounted under right side,lines are on it ready to go to your trans,if you check you see that theres a new ruel for crosmembers (25.5) this is done,and ready,rad has the fans mounted to them,even the batt is in the box, has a nice remote batt charging hookup, of course a master shut off,that is also wired to kill alt charging,chute is packed,and will be good for a while yet, rear end was out over last winter and on the jig to make sure not bent or twisted,
2 fuel lines run to the front,carbs/nos, theres a lot of work making the steel doors removable,and lite, theres no way to do this car for what im asking
thanks
would make a good home for any ford engine
Discussion Starter #16
SOLD, THANKS TO ALL
-RICH
I KNOW ILL MIS THIS CAR!!!!!!!!!!!!!!!!!!!!!!!
1 - 16 of 16 Posts
