Mustang
1989 Ford Mustang x275 It HAD a 572ci BBF Nitrous combo with a powerglide and went 5.20's with a 1.20 60ft on a 275 radial. The engine and transmission have been SOLD. This is just the ROLLER! Just a little over a year ago the car went up to RACECRAFT in Minnesota and had $8k in upgrades. This car has everything it needs to go racing but, the engine and transmission. This Mustang has mostly raced NO PREP, Grudge races and occasionally the local X275 classes. Titled and Tagged! Below is a list of EVERYTHING the car will come with!!!
List of parts
· Braced 8.8 with 373 gears
· 35 Spline Strange Axles
· Strange Spool
· Afco BIG GUN Coilovers
· UPR Anti Roll Bar
· Racecraft Lower Housing Brackets
· Racecraft Uppers and Lowers
· LPW Ulitmate Aluminum Cover
· Racecraft Crossmember
· Drop Spindles
· Caster Camber Plates
· Tubular A Arms
· Manual Rack
· RACECRAFT Steering Kit
· Strange Adjustable Front Coilovers
· Strange Disc Brakes
· Strange Front Hubs
· Vented Rotors
· Billet Specialties 15x12 Double Beedlock rears with 28x10.5 Slicks
· Billet Specalties Comp Series Front runners with M/T ET FRONTS
· Aluminum Lug Nuts
· 5/8 Rear Studs
· RACECRAFT Manual Brake Conversion W/ Master Cylinder
· Steel Braided Brake Lines
· Motor plate and Mid Plate for BBF
· Dual Drive Shaft Sensor for RACEPACK AND DAVIS TRACTION CONTROL
· BG 400 Fuel Pump
· -12 From Cell
· -10 to Front
· MINI TUBS
· 25.5 Certified Cage
· Front Exit Headers for P51 Heads
· Simpson Chute
· RACECRAFT Strutless Wing
· 15 Gallon Fuel Cell
· 16 VOLT Battery
· RACEPACK SPORTSMAN Logger
· Digitial 7 MSD
· HVC Coil
· Kirkey Seats with Covers
· RACECRAFT Removable Steering Wheel
· Full Autometer Gauges
· Tach
· Oil Pressure
· Water Temp
· Nitrous Pressure
· Fuel Pressure
· NOS LAUNCHER Nitrous Controller
· DAVIS Traction Control Unit
· Daytona Sensors
· Cheetah SCS Shifter(FWD Pattern) with Electric Shift Solenoid
· 6" Hardwood Hood
· All Power windows and locks work
· Tilt Steering Wheel
· All OEM Glass
· Smoked Headlights
· Still has wiper motor
· NOS Purge Kit
· Front End Limiters
· C-Moly driveshaft 48.5 Center to Center
· Mark Williams C-Moly Shaft and Yoke 3" Shaft
12500.00 obo on ebay right now
What did it weigh with driver and fuel NOS bottles? Thanks
3250 with 200lb driver its a little heavy still has all factory glass and power windows plus theres added weight here and there it could lose 300lbs real easy
